Will spring lift plus budget boost spacers work together? OME + RE
Old Jan 25, 2013 | 09:38 PM
baeteamjk's Avatar
Default Will spring lift plus budget boost spacers work together? OME + RE
I have a 2007 JKU X with a Rubicon Express 2" BB spacer system and twin tube shocks. I also have heavy front and rear bumpers and 33's and eventually will get a winch. I have the opportunity to get an OME 2" HD lift kit (springs and shocks) and was wondering if I could use the RE spacers still with the OME springs for a little more lift. Is that OK? Do you see any problems with that or is that not recommended? Thanks!
Old Jan 25, 2013 | 09:56 PM
Pluke the 2's Avatar
No. but with thst much lift, you should probably get an adjustable front trackbar and adjustable front lower control arms.
Old Jan 25, 2013 | 10:40 PM
MangoWilly's Avatar
You can probably sell the budget boost for most of the money you spent on it. Then get a set of front and rear 1" teraflex spacers and keep them around till you feel your springs have sagged enough. I think adding the 2" budget boost to your lift will give you more lift than you anticipate. You don't wanna make your driveshafts mad either.
On a side note, that's just what i'd do, not telling you what to do
