Want to put 15" rims & 35s, does anyone know a brand that will fit over the calipers
Old Jan 26, 2013 | 06:06 AM
beermantsw's Avatar
Default Want to put 15" rims & 35s, does anyone know a brand that will fit over the calipers
Old Jan 26, 2013 | 09:06 AM
OH9JK's Avatar
JK-Forum Ambassador
Most of the alloy wheels will fit without modification. The steel wheels usually require grinding the caliper slightly.
Discount Tire has done a great job putting together a list of what is known to work.
Try Googling this - 15" MB72 alloy Vs 15" Steel wheels
Old Jan 26, 2013 | 10:55 AM
rvator's Avatar
I used US Wheel D window daytonas from Summit. 15x8 steel with a 4 inch bs. I bought a single first to check the fit and then got the other 4.
Old Jan 26, 2013 | 12:26 PM
revvinkevin's Avatar
I have the MB 72s from Discount Tire Direct. They fit perfect.
Old Jan 26, 2013 | 01:02 PM
stagedtrip's Avatar
Im stuck between ordering the mb 72s or cragar soft 8s.
Old Jan 26, 2013 | 05:12 PM
xerofall's Avatar
X2... easy as pie.
Old Mar 7, 2013 | 02:28 PM
stagedtrip's Avatar
i ordered cragar soft 8's, they just showed up so i tried one on. Had to grind quite a bit on the passenger front side, and just a little on the driver side. Fit just fine on the back. Now if my tires would show up tomorrow ill be happy
Old Mar 7, 2013 | 02:33 PM
rickc309's Avatar
With 15's there isn't going to be much clearance if you get any debris in-between the caliper and wheel, keep that in mind.
Old Mar 7, 2013 | 02:47 PM
stagedtrip's Avatar
very true, but its not like there is really that much clearance on the front with the stocker 16s im replacing and i havent run into any problems as far as that goes with them. I like the look of small wheel big tire, and the price factor of rubber between a 15" and 17" is a no brainer for me
Old Mar 7, 2013 | 03:37 PM
sgtkersh's Avatar
I have MB TKOs from DTD and they fit fine.
Sent from my iPad using Tapatalk HD
Name:	ImageUploadedByTapatalk HD1362703069.618781.jpg
