Whats normal rpms @70 mph?
Old Jan 26, 2013 | 06:13 AM
A7x2706's Avatar
Default Whats normal rpms @70 mph?
Im runnin 35s on a 2.5 inch lift on my 2010 jku sport so i assume it has the 3.73s. It was a 1 owner so i doubt they regeared and didnt tell the dealer when it was traded. I dont run a procal yet but i know everyone says their setup and stock gears suck. I dont really think its that bad and ill be purchasing a procal today but i was just seein what the normal rpms for these gears are @ 70 mine were right at 2600 with od off.
Old Jan 26, 2013 | 06:29 AM
Blatant's Avatar
I have a '12 JKU, manual tranny, 3.73s and 35s. I'm about 2k (maybe 2,100) in sixth at 70 mph.
Old Jan 26, 2013 | 06:37 AM
OscarTheJeep's Avatar
Sounds like stock gearing to me.
Old Jan 26, 2013 | 06:55 AM
A7x2706's Avatar
I guess im tryin to figure out if im runnin normal or high. Like i said im not unhappy with how it drives, clearly its take off speed sucks ass but its a jeep.
Old Jan 26, 2013 | 07:31 AM
MiJKguy's Avatar
Default help
I got a 3 inch lift with 35's should I be driving with the OD off or on?????
Old Jan 26, 2013 | 07:42 AM
A7x2706's Avatar
Od should be off so you dont search for gears all the time
Old Jan 26, 2013 | 07:51 AM
MiJKguy's Avatar
Default ah I see
thank you! I have been driving with it on all this time , what should be the the rpm when doing 70mpr on highway?
Old Jan 26, 2013 | 08:02 AM
A7x2706's Avatar
I woukd assume if you have the 3.73s like me it will be somewhere around 2600 without a procal with one it would be a little better i woukd assume
Old Jan 26, 2013 | 08:08 AM
MiJKguy's Avatar
cool thanks that sounds about right
Old Jan 26, 2013 | 08:18 AM
jadmt's Avatar
JK-Forum Ambassador
actually driving with od on or off should be determined by terrain, speed etc. If it is in od and not hunting or lugging you will be fine. why run at 2600-2800 rpms driving down a flat interstate at 75 when you will be fine at 2200rpm etc. let your vehicle tell you what it needs.
