rear shock install, what direction? (fox 2.0)
Old Jan 26, 2013 | 07:02 AM
tlminh's Avatar
Default rear shock install, what direction? (fox 2.0)
Does it matter what direction the rear shocks go in? i.e. gas tube on bottom with shaft pointing upwards? Or gas tube on top with shaft pointing downwards?
Old Jan 26, 2013 | 07:06 AM
tlminh's Avatar
vs
seems like they can go either way, and fox install sheet doesn't mention anything about it.
Any pros and cons of either way?
Old Jan 26, 2013 | 08:25 AM
JLsJK's Avatar
I inverted the rear shocks on mine, with the shock body on top. Seems to me the body is less likely to be hit and damaged.
Old Mar 6, 2013 | 09:21 AM
tlminh's Avatar
Has anyone taken a bump to it? Just wanted to see what other people are running
Old Mar 6, 2013 | 09:39 AM
helnbk's Avatar
Always thought nitrogen charged shocks had to be mounted body side up?
Old Mar 6, 2013 | 10:05 AM
rinkishJK's Avatar
The body goes up.
Old Mar 6, 2013 | 10:06 AM
DanieltheManual's Avatar
Bar pin up.....? Is there another way....
Old Mar 6, 2013 | 10:10 AM
EzK's Avatar
EzK
I'd mount them up for clearance and protection. Isn't the bar pin on the body end anyway?
Old Mar 6, 2013 | 10:16 AM
suds1485's Avatar
I'm not sure but the should only go one way. At least that's what I thought. I haven't installed aftermarket shocks yet just extensions. The reason I say one way is because the mounts are different unless the bracket piece just slides through one of the holes. Or the manufacture makes them specific to the vehicle.
Old Mar 6, 2013 | 02:35 PM
Jp3792's Avatar
The rubber housing should be down this allows for it hit the rubber harder and save the shock, it also allows the shock to be protected from rocks and debris flying off your tires or when you are out
