adding spacers to existing lift...?
Old Jan 27, 2013 | 09:16 AM
EsByrd's Avatar
Default adding spacers to existing lift...?
I have the rough country 3.5 series2 lift and im having problems scrubbing when I have 4 people and some luggage on a trip I made and it was getting very annoying. So my question is could I add some 3/4 or more spacers and be ok? I plan on going with the airlift 1000s soon but when I do that im goi g to be adding a compressor and having them controlled by the pump but thats more than what I wanna spend right now
Old Jan 27, 2013 | 10:24 AM
10rubiconfun's Avatar
Spacers
Remove your stock idolaters and install a two inch coil spacer. This will give you one inch overall. It will probably run 140 for front and rear.
Old Jan 27, 2013 | 10:51 AM
EsByrd's Avatar
Would I run into any problems tho having 4.5 inches of lift with just a drop bracket for my brakes and a stock drive shaft
Old Jan 27, 2013 | 11:15 AM
gunbo75's Avatar
Yes you will need longer brake lines maybe a rear drive shaft. Thinking on the drive shaft. what size tires are you running.
Old Jan 27, 2013 | 12:16 PM
EsByrd's Avatar
Im running 37 trailgrapplers. Also would my n2.0 shocks be long enough
Old Jan 27, 2013 | 12:26 PM
EzK's Avatar
EzK
If he's fine for brakes right now I doubt spacers will affect that. Down travel will still be equally limited. But I can't even run stock brakes on my 2.5" lift so I donno how he's doing it now.
Old Jan 27, 2013 | 12:28 PM
Jersey_Devil's Avatar
Got the stock lines on my buddies with a 2.5" Skyjacker sport lift and 3/4" Daystar coil spacers and he's fine.... I'm gonna add the same spacers to mine to make up for the bumpers and winch and stuff
Old Jan 27, 2013 | 12:36 PM
Ncb's Avatar
Ncb
Sounds like you need to do some trimming and maybe extend the bump stops a bit.
Old Jan 27, 2013 | 01:10 PM
Ryan0260's Avatar
I wouldn't really go over 1" on the spacers. If you need more than that, go with different springs
Old Jan 27, 2013 | 02:15 PM
EsByrd's Avatar
Ive already trimmed and if I bumpstop more then it would beat me to death on those bumps. I have the 3.5 series 2 kit that comes with drop brackets for the brake lines and have no problem with stretching them right now but im not sure if I would be okay with the spacer is why I added this thread. Has anyone on here added a spacer to a 3.5 lift yet?
