Help or advice
Old Jan 28, 2013 | 06:16 PM
Fusco10's Avatar
Default Help or advice
Ok I have a 2.5 inch lift on a 2012 2 door wrangler.its a sky jacker lift. I have 33 inch pro comp mud terrains. My jeep rides pretty stiff and I notice hitting pot holes at slower speeds makes the jeep shake a lil. My questions are. Will better shocks give me a better ride. And what could cause this shake in front end. And it's not death wobble.
Old Jan 28, 2013 | 06:20 PM
swaite3's Avatar
How much air is in your tires? Depending on the load range on your tires, 26-30 psi might help
Old Jan 28, 2013 | 06:29 PM
Fusco10's Avatar
I run nitrogen and run them at 30.
Old Jan 28, 2013 | 06:35 PM
JK yeti's Avatar
Shocks will make for a better ride but before you go and spend your money check a couple of things, check your ball joints, tie rod ends, drag link, track bar bolts, pitman arm and the sector shaft, make sure they are all tight and there is no play in any of that stuff
Old Jan 28, 2013 | 06:41 PM
Fusco10's Avatar
Ok I'm not super good with wrenching. I checked all them bolts for tightness but how do u check if their bad. ?? Also I bought like 30$ shocks with the lift I went cheap. I was low on cash. So their really cheap shocks
Old Jan 28, 2013 | 06:54 PM
Atch's Avatar
If you got cheap shocks & coils chances are that's the problem- typically you get what you pay for
Old Jan 28, 2013 | 07:00 PM
Fusco10's Avatar
Coils aren't cheap it was a good kit. Shocks were really cheap. But I can't figure out the front end thinng
Old Jan 28, 2013 | 07:03 PM
Atch's Avatar
The jeep shakes or is it bump steer or flighty? How much actual lift did you get?
Old Jan 28, 2013 | 07:07 PM
Fusco10's Avatar
What is the difference. ???i mean it shakes the steering wheel back and forth pretty fast but not anything that u can't control. And it's a 2.5" lift
Old Jan 28, 2013 | 07:08 PM
Fusco10's Avatar
Not sure what the difference is between them all
