Spacer vs coil lift
Old Jan 28, 2013 | 06:28 PM
Jesseb73's Avatar
Default Spacer vs coil lift
Being the cheap skate I am, I've always had coil spacer lifts. What advantages are there moving to a true coil spring change if the change in lift height is equal? (ie. 2.5" spacer lift vs 2.5" coil lift)
Old Jan 28, 2013 | 06:32 PM
JK yeti's Avatar
The coil lift will not sag because there are higher progressive rate springs.
Old Jan 28, 2013 | 06:42 PM
Jesseb73's Avatar
Is there a difference in on/off road performance with such a minimal lift? Other than playin around at the deer lease or river i go to off road parks about 4 times a year and try to make one jamboree once a year.
Old Jan 28, 2013 | 06:58 PM
JK yeti's Avatar
Yes with coils you will have more up and down travel otherwise known as flex
Old Jan 28, 2013 | 07:00 PM
Jesseb73's Avatar
Gotcha. Thanks.
Old Jan 28, 2013 | 07:05 PM
JK yeti's Avatar
Gotcha. Thanks.
No problem
Old Jan 28, 2013 | 07:21 PM
madmike232's Avatar
Also depends how big you want to go 2 inch is about the biggest spacer lift.
Old Jan 28, 2013 | 09:12 PM
Tripletsi's Avatar
Firmer ride, usually an increase in weight carrying capacity without the sag effect prominent to stock springs, more flex as others have stated.
Old Jan 29, 2013 | 06:11 AM
Rock Krawler Suspension's Avatar
Former Vendor
The nice thing about a simple coil spring lift like our 2.5" Stock Mod. or 2.5" Flex System is they are great starting points for continued builds. You are not just throwing your money away.
No matter what you decide. Good luck with your build!
RK
Old Jan 29, 2013 | 04:35 PM
Smashboogie 4x4's Avatar
Former Vendor
Personal opinion but the Flex would be the starting point I would go with. Its just nice to be able to correctly set caster.
