teraflex 2.5 budget boost with Bilstein 5100s
Old Jan 31, 2013 | 05:20 AM
jkjouster's Avatar
Default teraflex 2.5 budget boost with Bilstein 5100s
any input from install tips, to ride experience is welcomed.
will be installed on a 2012 jku Sahara on stock 18 inch tires, but aftermarket 4.5 backspaced rims.18x9 i am sitting wider then stock
looking for input on the ride i should expect with the 2.5 pucks with bilsteins on the sahara springs. not the tallest ones i beleive, but i had almost no rake from factory.
install tips are appreciated too
Old Jan 31, 2013 | 06:00 AM
emiles1987's Avatar
Use grease on the pucks when pushing them in the 'upper spring perch', bump stops in the front are kind of a pain to set in place. Besides that the BB is a fairly easy/quick install (3 Hours +/-)
Old Jan 31, 2013 | 06:03 AM
jkjouster's Avatar
also interested to find out how much flex i can expect without having a space or spring unseat, would limiting straps be overboard, or will the bilsteins keep me good
Old Jan 31, 2013 | 06:09 AM
emiles1987's Avatar
The shocks hold the negative travel well.
Old Jan 31, 2013 | 09:25 AM
jkjouster's Avatar
anyone else running the budget boost on their JKU with Bilsteins? or aftermarket shocks other then teraflex
Old Jan 31, 2013 | 01:25 PM
janders82's Avatar
Is that the TF BB? Looks like you're getting a fairly good amount of flex with stock springs!
Old Jan 31, 2013 | 01:26 PM
janders82's Avatar
I ran the TF 2.5 BB with Rubi take-offs. Felt just like stock. Install is easy and straight forward. Took me about 4 hours
Old Jan 31, 2013 | 03:46 PM
Kirbdog44's Avatar
I have this exact set up but i installed AEV control arm drop brackets and a skyjacker 3/4 inch spacer up front it gives it a much better look, even with the BB the front will still sit lower. The ride is better than stock i think. So far so good install is pretty straight forward, youtube-teraflex budget boost install, it'll be the first video and just follow the video. Good Luck
Old Jan 31, 2013 | 05:33 PM
kh202's Avatar
Got the tf BB with just the shock extensions for now and I think it rides just fine, no complaints whatsoever. Bilsteins will just sweeten the deal, don't think you'll be disappointed. Only flex shots I have so far.
My plan is to upgrade shocks when the time comes. Just got rubi take offs not too long ago
Old Feb 1, 2013 | 05:47 AM
jkjouster's Avatar
did you ride the budget without the control arm brackets first, or install at the same time? interested to see if i should put the order in for the brackets as well, or wait and see if i deem them necessary
