Tire pressure???
Old Jan 31, 2013 | 05:22 AM
PiratesFan's Avatar
Default Tire pressure???
What tire pressure should i be running this time of year temp here runs about 35 and down... Tire size is 33x12.50 17 ?
Old Jan 31, 2013 | 05:26 AM
ronjenx's Avatar
Run the pressure you normally run.
When the pressure drops from the lower temperatures, pump it back up to normal.
Old Jan 31, 2013 | 05:29 AM
PiratesFan's Avatar
I just bought in dec used with this size already on there and have never had a tire that big... And I'm pretty sure I don't go by the door sticker factory pressure correct?
Old Jan 31, 2013 | 05:35 AM
ronjenx's Avatar
My post was aimed at the "this time of year" part of your question.
You'll get a lot of different opinions about what the psi should be.
Old Jan 31, 2013 | 05:37 AM
SpicedCrusher's Avatar
There is no universal tire pressure. Tires are all different. Some things you need to figure out yourself. Do the chalk test and go from there.
Old Jan 31, 2013 | 06:25 AM
PiratesFan's Avatar
Thanks guys
Old Jan 31, 2013 | 09:24 AM
Ryan0260's Avatar
Yep do a chalk test and drive it
