Backspacing confusion with 2.5 lift
Getting a 2.5 inch RC suspension lift done. I plan on running the stock 18 inch sahara wheels and tires for a brief period of time. Is there any issue with this?
I will then be replacing them with procomp 7089 (4.5 backspacing) with 305/70r16s. I believe there is then no issues with this setup.
I am just getting confused with the whole backspacing thing....and sounds like it only affects the stockers if I switch to a different tire.
thanks
thanks
That's my understanding as well. If you want to keep the stock Sahara wheels but go to a larger size tire (305- or 315-) you'll need spacers to correct for the stock wheel backspacing (which, without spacers, puts the inside wall of the larger size tire in contact with suspension components). But the stock wheel/tire combo will be fine with your lift.
