swaying/wandering at high speeds after 2.5 lift
Old Feb 2, 2013 | 03:41 AM
joey0480's Avatar
Default swaying/wandering at high speeds after 2.5 lift
I had a 2.5 Rc suspension lift done yesterday. When I hit about 55 mph and up, I am noticing it gets very flighty and pulls to each side. I did have the rear track bar relocator done and the front adjustable track bar. I will be getting the quick release front sway links in about a week. Any ideas?
Old Feb 2, 2013 | 04:15 AM
olyelr's Avatar
Have your caster checked. You will probably need adjustable lower control arms to get it back into a tolerable area.
Old Feb 2, 2013 | 04:18 AM
Jeepstin12's Avatar
What he said.
Old Feb 2, 2013 | 05:17 AM
joey0480's Avatar
Even with a small 2.5 lift?
Old Feb 2, 2013 | 06:18 AM
Ncb's Avatar
Ncb
Yes. The caster will be low enough to give it a flighty feel on the highway.
Old Feb 2, 2013 | 06:28 AM
RKracing's Avatar
Plain and simple.............You need front lower control arms.
Old Feb 2, 2013 | 06:35 AM
TXJfrosty's Avatar
or you can go with these... I'm thinking about going to them
Jeep JK Control Arm Relocation
i have a 2.5 TF lift (4dr lift on my 2dr)... but I also have a Daystar 3/4" spacer lift on top of that (closer to 3.5" of total lift). she's a little flighty, but it hasn't bothered me so far.
Old Feb 2, 2013 | 01:24 PM
olyelr's Avatar
Yep. Brackets are an option also. But, not a much less $ than new arms.
2.5-3" is right where the JK will start getting the flighty feel. I swear, mine has a slight flightyness bone stock. I bet when I go with a 2.5" lift I will have it bad. Others swear they have no issues at all with stock control arms and 3 1/2" of lift. All depends on the particular Jeep IMO.
Old Feb 2, 2013 | 05:24 PM
otservice's Avatar
When you had the lift installed did they keep the stock sway bar links on the front or just take them off for the time being? Without the sway bar connected you'll get wandering and bad cornering of course. Could also be a caster issue or just a loose bolt. Check all the bolts of the suspension if you can as they should be checked a few hundred miles after install and re-torqued if required.
We have a 5" lift on a 2dr and it doesn't get flighty. It does drive fairly straight for being lifted so much and without having any adjustable control arms. Although arms are next on the list when I get some time to either make them or $ to buy them.
Old Feb 5, 2013 | 03:32 AM
joey0480's Avatar
The front is still connected. I am going back next week for a re-torque and to get the quick disconnects put on in place of the stock endlinks. I put all the pressure to the new tires to about 32 psi as well. It is not as bad, but when I start to hit around 50 - 55 and up, it just feels like she is wandering....tad flighty. Maybe just the wider tire grabbing the grooves, but it seems a bit more than that.
