2012+ JK 2 door Extended Fuel tank
Does anyone make such a product? Or will the fuel tank from a 4 door JKU fit a 2 door? Range is a primary concern expecially when going on long trips.
Somebody (Polly Performance I think) makes a tank that goes in the rear like the TJ. You could install that tank and add a valve to switch between the two tanks for double your current capacity.
Also, talk to your local hot rod shop. You could get a custom tank made to fit your needs.
Nope right now it would be a custom job.
Personally I carry (2) 5 gal cans when making long trips. Think about how many times you can fill those with fuel vs purchasing and installing a custom fuel tank.
GenRight makes a 20 gallon fuel cell for the 2dr, it replaces the rear trunk. I looked in to it for the jeep when i purchased but with cost and other factors i decided to go with an orfab carrier with rotopax cans.
