Control arm ?
Old Feb 3, 2013 | 06:33 AM
Gman*2007's Avatar
Default Control arm ?
My front axle was off 3/8" so I just installed an adjustable track bar with disco sway bar links & rear adjustable sway bar links on 2012/3" leveled JKU. It had factory links on it & now it feels a little flitey in the rear. I was wondering if the control arms need to be changed out now. Any info would be appreciated.
Old Feb 3, 2013 | 07:47 AM
Pluke the 2's Avatar
Depending on how much lift you got, you may need a rear trackbar bracket and in extra cases you may need an adjustable rear trackbar
Old Feb 3, 2013 | 07:50 AM
But negative on the control arms
Old Feb 3, 2013 | 10:23 AM
Gman*2007's Avatar
A rear track bar bracket came with the Pro Comp Level kit. I was going to have the front end aligned but wanted to find out about the control arms brfore. Thanks.
