Bullydog GT for 5.13 gears adjustment
Old Feb 3, 2013 | 10:58 AM
mailman2000's Avatar
Default Bullydog GT for 5.13 gears adjustment
I have the Bullydog GT tuner had 5.13 gears installed but can't find anywhere to adjust gear ratios. Does anyone know if it will or do I need a new programmer?
Old Feb 3, 2013 | 05:05 PM
Mhare's Avatar
Try setting it back to stock. Then installing the tune you want. It will let you set gear ratio then.
Old Feb 4, 2013 | 06:31 AM
ok will try that thanks
Old Feb 5, 2013 | 03:17 PM
Well found out Bullydog doesnt allow gear ratio changes they said they are working on now.
Old Feb 18, 2013 | 02:00 AM
Mhare's Avatar
Mine let me change the gear ratio.
