JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Hot oil light? Help
Old Feb 12, 2013 | 07:38 AM
bastard431's Avatar
Default Hot oil light? Help
my hot oil light has come on twice now. Both times on a paved up hill road to my private range. Im in two wheel drive as it is a paved road and not a steep incline. It gets hot and goes well limp mode from what ive read. What is the cause of it should i be in a differnt gear or drive. Any help would be great. Thanks
Old Feb 12, 2013 | 07:47 AM
Red Wings's Avatar
I am assuming it is an automatic. Maybe try turning off the overdrive.
Old Feb 12, 2013 | 07:53 AM
bastard431's Avatar
Yeh its an automatic. I will try that
Old Feb 12, 2013 | 08:06 AM
profebill's Avatar
Its a problem, a big one. A cheap, easy, fast solution is go to an auto parts store and but an aftermarket auxiliary oil cooler.doesn't mater which kind, just get the biggest one cause why not. Buy around six foot of transmission tubing and the connector nipples to go with it. You'll need two. Total cost of everything is maybe seventy bucks. Take your grill off and use thick ass zip ties to mount the oil cooler in front of radiator and splice the new tubing into the old ones. Tada! Total work time ten minutes. Don't forget to add extra tranny fluid. Just read the write up on it here in the forums . Not only will this solve your overheating oil issue forever but also stop the blast furnace effect coming from the tunnel due to the torque converter imitating a small sun.
Old Feb 12, 2013 | 08:14 AM
bastard431's Avatar
Thanks man i appreciate this. Can you send me the link to the write up
Old Feb 12, 2013 | 08:58 AM
Freewill's Avatar
If you are going up hill in a JK automatic, then OD is off anyway.
You didn't say what your road speed was, or how many RPM the engine was turning. If you could shift down one gear without the engine screaming, then the torque converter wouldn't slip as much and less heat would be generated. If the grade is steep and the altitude is high, you might need 3500-4000 RPM on the engine to keep the torque converter from acting like a 1951 Buick Dynaflow.
But the best permanent solution is an auxiliary transmission oil cooler.
Old Feb 12, 2013 | 09:45 AM
Red Wings's Avatar
Steady uphill yes, but uphill with level parts it would be going in and out.
Transmission cooler is definitely the best fix and was one of my first mods.
Old Feb 12, 2013 | 10:01 AM
tcdawg's Avatar
ten minutes? It's not a day long job but it will take you longer than ten minutes. Give yourself an hour or so and google it for write up so you can ensure you route the tubing correctly into and out of the cooler.
and don't ziptie it in. when you find some write ups they will show you some options to install in with self tapping screws.
