Jku 08 pulling left and wanders
Old Feb 12, 2013 | 01:09 PM
devildogchoppers's Avatar
Default Jku 08 pulling left and wanders
I need some input to a problem that I can't seem to resolve.
I have an 08 JKU that is pulling left and feels like it wants to wander a bit. The steering wheel is centered and the JK will start pulling left. I have to turn the wheel right to straighten it out while driving. Once I get it straight, the JK and the steering wheel, it wants to wander a tiny bit right then back left again.
This is what I have tried so far...
Wheel is centered.
Tire pressures are exact and played with it at 28 psi to 32 psi.
Everything is tight and doesn't seem to have any play in the front.
I switched tires from left to right. Switched from my TOYOs to KM2s. No change.
Keep in mind that everything was perfect until about a month ago and no changes have been made to cause the pull. The only change was swapping my tires, but the problem was there before the tire change.
I did notice today that the steering box is leaking fluid and for 4 years have had a clunk in the steering that no one could actually find nor fix.
I have an appointment with the dealer Thursday to replace the steering box. Can the steering box cause the pull?
Any help or experience would be GREATLY appreciated!!!
Old Feb 12, 2013 | 01:11 PM
TURTLECON's Avatar
How's the steering stabilizer? Is it in good shape? Has it tweaked over at all?
Old Feb 12, 2013 | 01:13 PM
Ryan0260's Avatar
Is there play in the steering wheel? Also, what steering stabilizer are you using? Some gas charged units are known to pull one way or the other. Also, the Toyos are known to pull to the left a little.
Old Feb 12, 2013 | 01:28 PM
The steering stabilizer seems to be ok overall, but I can't tell. It has no signs of impact or movement from where it was installed. It is a Rancho stabilizer and it is about 3 years old/35k on it.
The tires currently are my KM2s. The TOYOs were on it recently but the pull actually seemed worse after I put the KM2s back on, but with tire pressure it seems a bit better.
Old Feb 13, 2013 | 02:13 PM
JKred's Avatar
How tall of a lift are you running? What are you using for caster correction? When was the last time you had an alignment?
Wandering could be poor or shallow caster, or worn TRE's, ball joints, etc. Pulling one way or the other could be improper toe.
Just some suggestions...
Old Feb 13, 2013 | 02:25 PM
Staytru06's Avatar
Check the toe I had this problem where I thought my steering wheel was not centered but the tow was off by a degree on the right side which who knew it could make a noticeable difference.
Old Feb 13, 2013 | 03:00 PM
JKred's Avatar
Also noticed you said your steering box is leaking... Any play in the sector shaft?
Old Feb 13, 2013 | 03:49 PM
Ryan0260's Avatar
I was wondering this too.
Old Feb 21, 2013 | 08:33 AM
I took it to the dealer and of course my extended maxcare warranty does not cover the stupid steering gear box. The good news is that they did confirm that the box was definately the problem. The play in the sector was enough to cause the strange steering response and wander and the leak was worse than I thought! The good news is that I found a reman box at Autozone with a lifetime warranty. I just installed it and whoooaaaa the steering is perfect! No more major clunk or wander and it feels tight again! As Ferris Bueller once said... I highly recommend getting one! So choice! lol
The new box is from duralast I think and the warranty should get me through again till it happens again. I could not tell if it was the Chinese unit or not.
Thank you guys for your help and comments! It helped me point out other things that I didn't originally think about. Funny how I can diagnose issues on other vehicles, but can't on my own!!!!
Old Feb 21, 2013 | 09:03 AM
Ryan0260's Avatar
Good to hear you got it fixed.
