Smittybilt xrc bumper with winch
2012 jk just put on a xrc front bumper with the smittybilt x20 8k winch and I am having trouble installing the 2 rear bolts to hold the winch on and outing the factory grill back on. Anybody have this bumper with a winch having the same problem and how did you solve it. Thanks
I had the same issue installing my Engo winch. I had to move the holes on the bumper forward about 1". If you do this make sure you have enough clearance between the bumper and the winch motor. After I did mine you couldn't fit a hair between them. Good luck!
Any pics would be great
Which bumper spacer are you referring to? What come to mind are the one-piece, double hole "washer" type things that go under the nuts in the back and the crush cans on the front of the frame rails. Please specify?...
