Swapping s rubi transfer case into a x
Old Feb 13, 2013 | 07:28 AM
Mhare's Avatar
Default Swapping s rubi transfer case into a x
I'm pretty sure this swap is straight forward, but are there any items I should upgrade on the case before installing it?
Old Feb 13, 2013 | 08:14 AM
pwain's Avatar
I assume you have already ensured its swapping from an automatic to an automatic or manual to manual?
Old Feb 13, 2013 | 04:14 PM
Mhare's Avatar
Yes it is an auto from an 08 going into an auto 07.
Old Feb 13, 2013 | 07:36 PM
jaker t5's Avatar
Does not matter if it's a stick or auto they cross over , just make sure they are the same case
Off my head they all cross over execpt the 2012 and up
Old Feb 13, 2013 | 09:06 PM
iwaxmyjimmy's Avatar
Do you already have the t-case? Since yours is an auto, the Rubi-crawler range box is a pretty nifty idea.
Old Feb 14, 2013 | 10:40 AM
09jaykay's Avatar
You should look into installing the teraflex 2lo in to the transfer case before you install it.
Old Feb 14, 2013 | 10:46 AM
Delux2769's Avatar
I would second this idea. Great for when you are on the pavement and need that extra low gearing, but don't want to accidentally break a front axle shaft ( know too many people at boat ramps that this has happened to by putting their Jeep in 4LO to pull boat up ramp.)
Old Feb 17, 2013 | 11:32 PM
Mhare's Avatar
I do not have the rubi case yet. Will be picking it up Saturday. I like the rubi-crawler. But didn't like the gearing choices you get with the x case. Since the rubi-crawler low and my current low are both 2.72:1. I was thinking about adding a rubi-crawler after the rubi case and after ditching the dana 30.
I'm not going to install the 2-lo kit. Simply because my long term plans are to add the rubi-crawler. I would then have a 2.72:1 2-lo.
Old Feb 18, 2013 | 08:32 AM
You do realize your crawl ratio will be ridiculously low with a rubi case and a rubi crawler range box? 2.72x4.1x whatever your gear ratio will be. And with a Rubi-crawler will have a lower low range than a standard Rubicon t-case.
Old Feb 18, 2013 | 08:36 AM
CerOf's Avatar
You don't have to have the super low combo ratio. You can pick and choose.
Rubi 4.1 only
Rubi 4.1 x crawler 2.72
Crawler 2.72 only
Crawler can be used in 2wd and 4wd.
So, you get the best of both worlds with the added SUPER low of having about a 10.xx low when everything is engaged.
