Any tips on aligning front LCA's with stock mounts?
Old Feb 15, 2013 | 04:09 PM
sjak's Avatar
Default Any tips on aligning front LCA's with stock mounts?
Good Evening,
Swapping out my coil springs and adding some adjustable front LCA's this evening. . .
Any tips on getting the bolt holes to line up? Had to pull in the axle to get the stock uppers to align and now are pulling out the axle for the lowers (pulling towards the front of the vehicle) with ratchet straps.
Using two floor jacks to adjust driver/passenger side axle height. .. . Can't seem to get the axle pulled towards the front enough to get the bottom bolt to line up? Is removing the front track bar critical? Have sway bars, shocks and tires removed.
Any feedback would be greatly appreciated for tomorrow's attempt!
Old Feb 15, 2013 | 04:44 PM
junokilo's Avatar
I used ratchet straps with the Jeep on the ground so it would move as I used the straps.
Old Feb 15, 2013 | 04:47 PM
k0260's Avatar
I use a ratchet strap too on the ground, around the axle and to my front bumper rings. If you have tow hooks that would work, otherwise the swaybar. No need at all to remove your track bar.
Old Feb 15, 2013 | 04:53 PM
aldaman's Avatar
Here is a link to the write up.....It uses the floor jack positioned into either at the axle or control arm brackets to help you get the arms in...
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Last edited by scooby snacks; Feb 15, 2013 at 06:05 PM. Reason: removed external link to non-sponsor
Old Feb 15, 2013 | 05:44 PM
sjak's Avatar
Thanks for the input and the link. I was assuming that it would be easier to hit that magic alignment spot with tires off and everything in the air.
Appreciate everyone sharing their experience. .. less cussing tomorrow!
Old Feb 16, 2013 | 07:05 AM
jk4thedirt's Avatar
If you are close, you can put a jack on the rear pinion and rotate the pinion upwards to gain a little more.
Old Feb 16, 2013 | 07:16 AM
Staytru06's Avatar
Ratchet straps ftw deff helped me out A LOT. Also once I was able to grt the bolt started through a lil persuasion with a hammer, don't kill the bolt but nice gentile hits, helped, me out.
Old Feb 16, 2013 | 09:02 AM
Freewill's Avatar
My buddy, who just had open heart surgery and couldn't use his arms, sat on a chair and moved the axle with his boot to line the holes up for me.
