1st Gear Question - 4:10's, 6-Speeds, 35s
Model in question: 2013 Rubi 2-door, 6-speed, 4:10 gears (all stock)
The only time I can utilize 1st gear is when I'm creeping around off-road, otherwise 1st gear is way too low for me out on the street. I always start off in 2nd gear.
So I'm wondering if by changing my factory Rubi tires to 35s, will 1st gear be more usable on the street?
I'll be installing a lift soon and I'm on the fence between 33s or 35s (per tire mfg specs).
Thanks!
Thanks!
How is first gear too low for you on the street? It's the perfect gear to use so you don't really have to slip the clutch much at all to get going. Yeah, it's a short shift to 2nd, but once you're moving, you never really see 1st again until you're stopped and have to get going again.
To answer your question, yes, the 35's will make 1st feel a little longer
We've got a 2013 Rubi Unlimited. The new engine is definitely worth it (we owned a Jeep with the 3.8 before). The seats are a nice improvement over the 2012's. Same function, but the cushions feel a bit longer and a bit softer on the hips and legs. Jeep's done a really good thing here with the new engine, new interior, etc.
