help to select roll cage.
Old Feb 16, 2013 | 07:01 PM
jc.mendez's Avatar
Default help to select roll cage.
hi guys, i have a 2dr and i want to install a roll cage, wich one would you recommend? also i want to reinforce the rear, thanks!!
Old Feb 16, 2013 | 07:36 PM
Atch's Avatar
A lot of guys are running the rock hard bolt on cage. I intend on going this route I'll be able to save money by installing it myself compared to a welded cage.
http://northridge4x4.com/shop/rock-h...2007-up-rh1030
Old Feb 16, 2013 | 07:41 PM
DesertJeep's Avatar
I'm very happy with my Rock Hard cage. Running the full sport cage with the rear center bar and harness bar behind the front seats. Very good fit and finish.
A couple friends run the Or-Fab cage which also looks like it's very well made.
Old Feb 16, 2013 | 08:22 PM
jc.mendez's Avatar
do you have any pictures? for install is required to cut some parts on the dash? thanks!
Old Feb 16, 2013 | 08:24 PM
jc.mendez's Avatar
Rock Hard Ultimate Sports Cage Jeep Wrangler JK & Unlimited 2007 - Up (RH1030)
hey man, what do you think about the EVO bolt on coilovers? i'm thinking to order them!
Old Feb 16, 2013 | 08:29 PM
DesertJeep's Avatar
I'll post some pics in the morning. No cutting to install, just drilling holes for bolts below the A pillars. Cutting of the A pillar molding is required if you want to reinstall it after the cage is bolted in.
Old Feb 16, 2013 | 08:34 PM
jc.mendez's Avatar
thanks for your help man, i will check tomorrow to see the pictures
Old Feb 16, 2013 | 08:49 PM
sick jk's Avatar
Running poison spyder cage and love it! Built well. Replaces the weak stock side bars and goes to the floor
ID:	423202   Click image for larger version
Old Feb 17, 2013 | 03:52 AM
Pete1971's Avatar
for those running the REAR support bar how are you positioning it to NOT interfear with your hard top or soft top ??????
Old Feb 17, 2013 | 05:22 AM
Atch's Avatar
Do you think I would be able to run the rock hard cage with my sPOD??
