Ever Break This???
Old Feb 17, 2013 | 04:58 PM
JKBANDIT55's Avatar
Default Ever Break This???
Its the boot on the Draglink under the passenger side. I just noticed it today when I was under the jeep. Not sure how long I have been driving like this.
Think warranty will cover it? How long do you think I can drive like this?
Old Feb 17, 2013 | 05:03 PM
olyelr's Avatar
Under the passenger side?
How many miles on it?
Old Feb 17, 2013 | 05:12 PM
ScruffyRubicon's Avatar
If it is under warranty, they should cover it.
Looks like a drivers side pic.
Old Feb 17, 2013 | 05:32 PM
JKBANDIT55's Avatar
Ooops ya your right. It is drivers.
I hope warranty will cover it. Just dont want them to see my 2.5" lift and 35s and try to void it. Although Im not sure if my lift and tires have anything to do with this failing...
Old Feb 17, 2013 | 05:33 PM
JKBANDIT55's Avatar
about 10k miles
Old Feb 17, 2013 | 05:36 PM
kssting's Avatar
12k on mine when the boot went. My dealer who has been great with everything else so far wouldn't replace it under warranty because they thought it looked like it could have happened when we installed the lift. $109 part and about 30 minutes of labor so it wasn't too bad.
Just realized it was your driver side so it will be even cheaper since you don't need the drag link. .
Old Feb 17, 2013 | 05:46 PM
JKBANDIT55's Avatar
Is it just something you bolt on? What part would I be buying exactly?
Old Feb 17, 2013 | 06:18 PM
havochaos's Avatar
Go to AutoZone or the like and get Moog ES3624. Much beefier and its greasable, and should be less than $30.
[edit]
Old Feb 17, 2013 | 06:44 PM
kssting's Avatar
It really is a bolt on part. Take of the nut holding the end on and then loosen the bolt on the adjusting threaded clamp and screw the old one off and then reverse the process for the new one. Just pay close attention to how far the stock one was threaded and match it as close as possible. You will know if its right if your steering wheel stays centered. If for some reason the wheel doesn't stay centered you can adjust it by simply turning the clamp by loosening both bolts on the clamp.
Old Feb 17, 2013 | 07:16 PM
JKBANDIT55's Avatar
Thanks. Do you know how long I can drive like this for? Just want to know if I need to hurry in to the dealer for the part or worry about it in a few weeks when I have time off from work
