Do balancing beads really work?
Old Feb 18, 2013 | 08:43 AM
mattgt5's Avatar
Default Do balancing beads really work?
I have some 37s and beadlocks to mount up and I want to know how bead balancing has worked for you guys? Dynabeads, airsoft pellets, something else? Please chime in with your experiences. Thanks
Old Feb 18, 2013 | 08:52 AM
rvator's Avatar
I used dynabeads on my 33x15's. tires are wearing good with over 20 k on them. I have taken a few long hwy trips at 70-75 mph and they rode smooth. When I was searching some guys liked them others hated them. I mounted the tires myself and said if it doesn't work I am just out the beads plus a trip to the tire store for a balance. I will run then next set and my EB will get them too on day.
Old Feb 18, 2013 | 08:57 AM
Kinless's Avatar
I am using balance beads in my 35 mtr/k's. First we spun the wheels and tires to figure out how much they were off. All 4 were about 4oz off. So we added 4.5 oz of beads. They work well for me. Others have had mixed reults.
I like them because I air down to 3.5 lbs for snow often and every once in awhile I spin the rim inside the tire a little bit. The beafs have been great because of that.
Old Feb 18, 2013 | 09:33 AM
mattgt5's Avatar
Thanks guys. Dynabeads has a chart in fire size and it says 10 oz per tire. So I bought enough airsoft pellets to do all 5. I guess I will do it and if it doesn't work, just get them balanced. The pellets cost me $15.
Old Feb 18, 2013 | 10:51 AM
ronin2120's Avatar
Vet Army
I'm using them in my Nittos and AEV Beadlocks and haven't had an issue with them going on 20,000 miles.
Old Feb 18, 2013 | 10:57 AM
mattgt5's Avatar
Excellent. Mine are mtz on aev beads. Did you install those tires? Any tips on getting the inner bead over the wheel?
Old Feb 19, 2013 | 03:05 PM
JohnnyQuik's Avatar
I'm looking forward to watching you jump on the tires to get the bead over. When I was having trouble balancing my Iroks, my research led me to this rather than balancing beads. That RimTyme place on Rivers has one and charged me 10 bucks a tire. Balanced them perfectly after the first place couldn't do anything with them.
Road Force Touch GSP9700 - The World's #1 Diagnostic Balancer
Old Feb 19, 2013 | 03:06 PM
mattgt5's Avatar
This is where I will go if the beads fail me. Bad part is I won't know it failed until ee are on our way back from Kentucky!
Old Feb 19, 2013 | 04:02 PM
azsandrider's Avatar
I would think the beads will work fine but you have to remove the sensors.
i run beads on my Goldwing and they work great.
Old Feb 19, 2013 | 04:07 PM
swaite3's Avatar
No reason to pull the sensors unless you are trying to put the beads in without breaking the bead on the tire....but you would need to do that to remove the sensors as well
