Changing Shocks?
Old Feb 18, 2013 | 09:59 AM
PiratesFan's Avatar
Default Changing Shocks?
How hard is it to change shocks it looks like the rear would take a matter of minuets but the front is my concern, is there anything special u have to do other than jack it up and pull the front tires off? Does it take a special size socket to take the top nut off of the shock? Any input would help and rear as well is it just a matter of jacking up and unbolting the top and bottom bolt then replacing the shock?
Old Feb 18, 2013 | 10:02 AM
5280transplant's Avatar
I just changed mine out for Bilstein 5100s. The process is very simple. No jacking up, taking tires off, or using unusual tools. The rears are really easy and the fronts are fairly simple. Just turn the wheel all the way to one side so you can access the shocks easier. PM me if you have any other questions. Here are some pics.
ID:	423777   Click image for larger version
ID:	423778   Click image for larger version
ID:	423779   Click image for larger version
Old Feb 18, 2013 | 11:52 AM
Scrambled's Avatar
What he said. ^^^
Old Feb 18, 2013 | 02:45 PM
snytribe's Avatar
Get a ratcheting wrench with flexible head to make it easier to get to the top old on the front shock. Have also red here some where that some people trim the plastic near this bolt on the 2012's.
Old Feb 18, 2013 | 03:00 PM
shockwaveaz's Avatar
^^^ makes all the difference
Sent from my SPH-L900 using Tapatalk 2
Old Feb 18, 2013 | 03:04 PM
PiratesFan's Avatar
Where can i find this at?
Old Feb 18, 2013 | 03:06 PM
Smashboogie 4x4's Avatar
Former Vendor
Sears will have it.
Old Feb 18, 2013 | 03:09 PM
16mm or 5/8. Pretty much the same thing.
Old Feb 18, 2013 | 03:12 PM
I used a 5/8 wrench with a angled head. it wasn't too tough. It all depends if the OP has a thick wallet. The ones I saw at Sears weren't cheap.
Old Feb 18, 2013 | 03:39 PM
Former Vendor
They won't be that cheap but they will definitely be cheaper than Snap On or Mac Tools. Craftsman is typically a great hobbyist tool as it has a life time warranty.
If you want cheap tools look at Harbor Freight, but cheap tools is what you will be getting.
