Cheap but effective air compressor?
Old Feb 18, 2013 | 02:50 PM
DMoore5's Avatar
Default Cheap but effective air compressor?
I have been looking around and found the smittybuilt 2.54 cfm air compressor, anyone have any experience with this one? How long it takes to air up 4 tires? Would I be better off saving up for a higher quality air compressor or will this work fine? Or any other recommendations? Thanks in advance for the help
Old Feb 18, 2013 | 02:54 PM
shockwaveaz's Avatar
Check this out.. Same thing. They actually don't make it. Just re branded. Been around for many years and works great for the $.. cheaper here
h t t p://www.northerntool.com/shop/tools/product_200442866_200442866
Sent from my SPH-L900 using Tapatalk 2
Last edited by scooby snacks; Feb 18, 2013 at 03:28 PM. Reason: Removed non-sponsor link; Displayed URL
Old Feb 18, 2013 | 02:58 PM
4W-Jive's Avatar
I've been using that smittybilt one for a year. It's been totally fine but I will upgrade to under hood soon, I have a 2 door and even that small of cargo space is valuable
Old Feb 18, 2013 | 03:02 PM
DMoore5's Avatar
Comparing the specs of the smittybuilt vs Q industries they seem about the same to me. Am I wrong? How long does your smittybuilt take to air up 4 tires?
Old Feb 18, 2013 | 03:04 PM
4W-Jive's Avatar
A little while, prob 6-7 mins each for my old rubi tires, but that's time just spent shooting the breeze and mingling anyways. Plus I'm at altitude.
Old Feb 18, 2013 | 03:06 PM
You're right smitty doesn't make it.
Old Feb 18, 2013 | 04:44 PM
Yarjammer's Avatar
I have the Craftsman version of that pump and it gets the job done, albeit slowly. On my old truck with 35's on 16's it would take up to 8 minutes a tire up in the mountains from 10psi to 27psi. Under 1000 ft it wasn't too bad at roughly five minutes. One thing I have noticed up here in the wet NW is that when I got my tires changed there was a few cups of water in each tire. I have been spec'ing out compact in-line dehydrator to put on mine to keep this from happening. When I can afford it a Powertank is in my future.
Old Feb 18, 2013 | 07:00 PM
4x4Play's Avatar
That Q-Industries one is less than $60 on Amazon! I've never used one, but would adding an air tank to the system speed anything up?
Old Feb 19, 2013 | 11:32 AM
Yes, it would.
