Pic Request 2 door w/ 35's NO LIFT and flat fenders
I saw 1 jeep with this set up in the "2Dr and 35's" thread, just wondering if there are more out there running this set up in the jk world. Please share your thoughts, opinions and pics if you have them. Thank you!
Don't plan on taken it on serious offload, just through mud and sand, that's why I'm wondering if I can get away without lifting it and putting flat fenders on to allow for clearance for minor flex and turning my front wheels. Don't know if I make sense or not, and this is just a temporary fix until I can afford the lift, I'd rather spend money on wheels tires and fenders and then install the lift, rather than lifting and looking retared on 16" steel pizza cutters.
Been running this way since fall. On road is fine, off-road is ok at best. Trimming of the pinch seam is a must, on or off-road. The stock suspension will flex, so if you have thoughts of disconnecting the sway bar....forget about it. Works for me till I can afford the setup I want.
Attachment 423968
Attachment 423968
