Pros and cons of spray bed lining the grill
I checked it out. It comes off so easily. If you go off roading you would have to touch it up all the time. The place I got my jeep from had one with the grill already sprayed so I got to check it out. It looks sick!!
I plastidipped mine. I thought about bed liner, but.... why?!?!? I can always remove the plastidip later and if it chips (which it hasne't in over a year) then I touch it up.
I bedlined mine the beginning of last summer and love it. I was nervous when I did it, but glad I did. Has absolutly helped on the rock chips and super easy to clean with a power sprayer. Plus, the shiny of the gloss paint on the hood and the flat color on the grill looks good. I took the jeep emblem off completly. Hope this helps
It was a horrible feeling taking sand paper to the grill to rough it up for the bedline to stick. Nothing like point of no return!
So far I've sprayed the bed liner on it and am about to do the DIY mesh mod.
I did a test fit of the grill before I started work on it and it takes about 10 minutes to swap the grills.
