RIPP Supercharger, Headers, and P0344 Camshaft Position Sensor DTC
Old Feb 20, 2013 | 01:53 PM
chripczuk's Avatar
Default RIPP Supercharger, Headers, and P0344 Camshaft Position Sensor DTC
So I put the RIPP headers and supercharger on my '08 JK, and loaded the RIPP SC and Headers tune on my ride. Now when ever I get on the freeway out of my place going uphill and accelerating, and after then coming back down the hill, all of a sudden the check engine light and ESP light goes on.
Pulled over, checked the code and get the P0344 "Camshaft Position Sensor A Circuit Intermittent" code. Reset the code and then get back on the highway and the check engine light and ESP light comes back on. I reload the tune and all seems good for a bit until I go back up and down that same hill, though it doesn't happen anywhere else.
Loaded the RIPP SC tune only, and it seems like all is good. Anyone else have this problem with the RIPP SC and header tune? Since it doesn't happen with the SC tune only, I'm wondering if it's a sensor problem, wires arcing, or connection issue, or maybe just a PCM tune issue on the header/sc tune?
I want the maximum tune capability, so just doing some troubleshooting to see how I can get the best tune (i.e. sc/header), versus just using the SC tune.
Name:	San Diego-20130217-00147.jpg
ID:	424763Click image for larger version
Name:	San Diego-20130214-00144.jpg
Old Feb 20, 2013 | 04:01 PM
dis_dis's Avatar
I am not an expert but did you get your tune from RIPP?
That's where I got mine and I don't have any issues with it. Also not sure what the headers tune is ...
Old Feb 21, 2013 | 10:45 AM
RIPPMODS's Avatar
Sponsoring Manufacturer
Attachment 424763Attachment 424764
Please take a data log with the included diablosport tuner, try to recreate the conditions under which the code appears and forward the log with a brief description to ripptuning@gmail.com. Lets see what's going on.
RIPP
Old Aug 29, 2013 | 09:44 PM
jway5929's Avatar
Default Solved?
Was this issue ever solved? I am having a very similar problem. Ripp SC (no headers) with latest SC only tune. P0344 is thrown repeatedly in situations with the most resistance (a combination of headwind, uphill, accelerating in a lower gear, towing/loaded down). Yet I can drive without code all day with no load/trailer, flat ground, no headwind. I bought the RIPP SC specifically to help with towing so this is really frustrating.
