truss vs sleeves: whats the verdict?
Old Feb 20, 2013 | 08:26 PM
tlminh's Avatar
Default truss vs sleeves: whats the verdict?
Been doing research on reinforcing the front d30. Lots of talk about sleeves and truss. Bout 50/50
Was looking at evo sleeves or artec truss kit. One of these will go along with some c gussets
So whats the verdict? Should I get the sleeves or the truss?
Old Feb 20, 2013 | 08:52 PM
shockwaveaz's Avatar
Truss will spread the load over a larger area. With that in mind. ..Not all are created equal. I recommend artec http://www.artecindustries.com/JK-Fr...uss_p_312.html
Sent from my SPH-L900 using Tapatalk 2
Old Feb 20, 2013 | 09:34 PM
BubbaJK2012's Avatar
If stay away from truss unless them guy installing/ welding knows how to install with the cooling process per weld.
Old Feb 20, 2013 | 09:40 PM
Philip *AZ*'s Avatar
I agree with shock. This is the same thing I may go to depending on if decide to stick with the D30. (Got my eye on an LS2 and a pair of D60's). I dont remember who did this but here is the finished result of his install.
ID:	424958   Click image for larger version
ID:	424959   Click image for larger version
ID:	424960   Click image for larger version
Old Feb 20, 2013 | 09:43 PM
As long as the installer of truss knows how to weld. Improper welding can do more damage when doing a truss
Old Feb 20, 2013 | 10:07 PM
Agreed 100%..
Old Feb 21, 2013 | 04:53 AM
Ryan0260's Avatar
I would do the gussets and maybe sleeves, and leave it alone. The housing isn't the weak point on a D30, it the small size of the ring and pinion gear. If you plan on wheeling hard, I would put my money towards a D44 or D60.
Old Feb 21, 2013 | 11:35 AM
tlminh's Avatar
I hear that a lot too, gussets and truss would cost me about 700 installed. How much would it be for a D44 installed? If it runs 4k, then I might as well get the gussets and truss and hope for the best
Old Feb 21, 2013 | 04:57 PM
Gman*2007's Avatar
I agree with Ryan, if you're planning on doing trusses your better off starting with at least a D44.
Old Feb 21, 2013 | 05:03 PM
GetOut's Avatar
Sleeved, gusseted, and trussed, its a super D30.
But as others have pointed out do not have just anyone with a HF welder go to town, you could run into some interesting issues
