? about the Teraflex hinged tire carrier
Old Feb 21, 2013 | 01:20 PM
scratchkenny's Avatar
Default ? about the Teraflex hinged tire carrier
I am getting my 35's on tuesday, I was wondering if I get the Teraflex hinged tire carrier will 35's still fit with my stock bumper? Thanks
Old Feb 21, 2013 | 02:05 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Yes it will fit. Now are you still using your stock wheels?
Old Feb 21, 2013 | 02:21 PM
theZombie's Avatar
My 35 fits just find
Old Feb 21, 2013 | 03:40 PM
yes I am still using my stock 255/75/17 wheels and tires. On Tuesday i will be putting on 5 M/T classic lock Black 17"
ID:	425169 Click image for larger version
ID:	425170 Click image for larger version
with 5 315/70/17 Fierce Attitude M/T (not the wheels I will be using)
Old Feb 21, 2013 | 04:59 PM
irongate's Avatar
No problem at all with stock Bumper and 35". Really a nice unit and strong.
Old Feb 23, 2013 | 05:27 AM
Sscarbrough52's Avatar
Get it for sure, installed this morning in an hour and is strong as an OX.
Attachment 425633
Old Feb 23, 2013 | 06:07 AM
rickc309's Avatar
With 4 1/2 backspacing of the Micky T's you might want to consider the adjustable mount also. Northridge 4x4 has the combo in stock at a great price. Other wise you'll either have to get creative with your tailgate bump stop or check out a Daystar extended bump stop.
Old Feb 23, 2013 | 06:29 AM
bob-o's Avatar
I have a 37" BFG km2 on the Moab wheel with the TF hinge and stock tire carrier. No wheel spacer, no rubber bumpstops, no problem. Been running like this for 5k miles and numerous offroading trips without any rattling or shaking. since I have the stock wheel on there, the wider tire gets pressed up against the hinge a little bit and that seems to prevent the tire to bounce around or shake. The TF hinge is freaking awesome and I love how its super light but strong as hell. Thanks TERAFLEX for making and awesome product!
Old Feb 23, 2013 | 07:29 AM
1230frstap's Avatar
Former Member
Hi,
Just came across this thread and it caught my attention. Like many others, the spot welds on the rear tailgate on my JK were coming apart at the top (on the inside, especially). I reinforced the tailgate with some machine screws and ended up custom fabricating a boat roller that fits into the rear hitch, so that every time I close the tailgate, the rear wheel hits the roller and rests on it, thus alleviating pressure off of the tailgate (I hope that made sense!).
Anyway, I would like to eventually remove the rear hitch and just use the tailgate carrier, but am afraid of the spot welds/thin sheet metal giving out and bending the tailgate. BTW, currently I am running 35's.
So, I was wondering if Teraflex's hinged bracket would take pressure/weight off of the spot welds on the rear tailgate, or if it just reinforces the hinges mostly? In other words, if I pull the trigger on the TF kit, will my problems with the tailgate spot welds come back or will this be an adequate fix?
All input is truly appreciated!
Old Feb 23, 2013 | 07:36 AM
rickc309's Avatar
Originally Posted by Ratso
Hi,
It will take all the tire weight off of the gate., they way it is now the weight of the tire is transferred through the sheet metal to the OEM hinge, with the TF hinged carrier the weight of the wheel is on the carrier and not on the sheet metal. It's totally what your wanting...
