How much lift is enough?? Where to begin???
Alright...here is my problem. I have a stock 2010 rubicon that I am starting to modify this spring and need a little help. This mamma jamma is still my daily driver to and from work but 4 or 5 times a year we go off times a year and it is pretty aggressive. This year I am adding a winch, new tires (replacing the factory bfg's 255 75 17) because rotating them every 3k got 70kmiles on them and adding a lift. The lift is were I get out of my comfort zone and get a little lost. I have an extra set of wheels so eventually those will house the mega tires and I want to make sure I have clearance so 3" or 4" and what is cost effective. Also looking for full doors and have had no luck with this so any ideas would be awesome. I am new to the forum but it looks like there is a wealth of knowledge here so thank you in advance for having me and helping me.
I am running 3.25" lift and 35's during the summer. I have 40K on the lift and probably 25k on the tires.
This is a daily driver with some travel on them. I have had no issues with the lift and tire size. I have the 6 speed manual with 4:10. With the 35's it is okay as long as you don't mind dropping a gear at every hill. hahaha
I run stock tires during the winter months.
The lift and shocks did change the ride quality to be stiffer than stock although I really don't notice it as I put the lift in with only 700 miles on the Jeep.
I find this amount of lift is just right for me and the uses I have for my Jeep. A 2.5" would also have been fine but I liked the 3/4" inch more.
Hope this helps.
Stay safe.
Mandor6863
Hope this helps.
Stay safe.
Mandor6863
