So I have 14/55 springs
Old Feb 22, 2013 | 06:22 PM
jbry311's Avatar
Default So I have 14/55 springs
Obviously these are the most basic springs that are offered, so it's time to upgrade. If I find a pair of 19/60 springs will I be able to use my stock shocks and will it lift my 2 door a couple inches? Thinking about a bb lift, but if I can get a 2" lift out of springs I'll do that.
Old Feb 23, 2013 | 04:27 AM
lowendrider's Avatar
with 19/60 combo you'll see a significant boost over the 14/55. I replaced just the front 14s on mine to offset a winch/bumper and mine sit higher in the front now with the winch and bumper than it did without.
Old Feb 23, 2013 | 04:29 AM
I forgot to mention..I used 17s in the front. My bumper and winch aren't the heaviest out there but still added an estimated 100lbs.
Old Feb 23, 2013 | 04:35 AM
catahoula's Avatar
Replaced my 14/55's with 18/59's and Rubi shocks. gained 1.5"-1.75" in front and wil add leveling kit down the road. Also running Rubi take offs which added additional height from 225's to 255's.
Next to stock stocker after additions
Before
After
Old Feb 23, 2013 | 04:42 AM
Gman*2007's Avatar
If you're needing 18/59's I have a set. PM me if interested.
Old Feb 23, 2013 | 05:16 AM
jbry311's Avatar
Does anyone know if I'll need rear track bar bracket and shock extensions if I throw on 35's with 18/59 springs and 1" spacers? Just wondering if I'll need the same things I'd get with a bb lift kit.
Old Feb 23, 2013 | 05:27 AM
SBEII's Avatar
You won't need a tack bar bracket. I would get the Rubicon shocks to go with the springs.
Old Feb 23, 2013 | 05:37 AM
jbry311's Avatar
So why do you have to install one with a 2.5 bb lift? I'd be at the same height with the rubicon springs and shocks that I'd be at with a bb. Just curious to know.
Old Feb 23, 2013 | 05:47 AM
SBEII's Avatar
You won't be quite that tall. I haven't seen a BB with a track bar bracket. Maybe you were thinking of end links for the sway bar? I know a couple guys running the 4dr springs and shocks on 2drs without any issues. I don't know about the end links. They have QD so they could be longer.
Old Feb 23, 2013 | 05:57 AM
jbry311's Avatar
Teraflex and RC BB's come with rear track bar brackets. I may get one just incase as well as a adjustable front track bar.
