Houston area hard top repair
Old Feb 23, 2013 | 02:15 PM
jeramiej's Avatar
Default Houston area hard top repair
Well I cracked my hard top today
Does anyone know of a repair shop around Katy/Houston??? I am in a bit of a hurry to at least get it dropped off at a shop as I leave Tuesday to go back to Brasil for a while
Any input is appreciated
Thanks
Old Feb 23, 2013 | 04:20 PM
gunbo75's Avatar
Try a boat repair Shop. Good luck
Old Feb 23, 2013 | 04:47 PM
jbry311's Avatar
I dropped mine from my old '07 and was so pissed! Not sure how bad your top is, but I had to sell mine as it was just to get it out of my garage because it would have been about $500 to fix it. Good luck!
Old Feb 23, 2013 | 07:05 PM
Ryan0260's Avatar
Thanks
Do you have any pics of the damage?
Old Feb 24, 2013 | 06:42 AM
jeramiej's Avatar
Default Pic of crack
It's on the passenger side rear corner and runs down to the seam behind the window, it is only on the surface and the inside is good
Old Feb 24, 2013 | 08:44 AM
Ryan0260's Avatar
Honestly, since it isn't completely cracked all the way through, I would just get a fiberglass repair kit and do it yourself. It will save u a ton of money. You can see how to do it on YouTube, it honestly isn't real hard, just time consuming. Once you finish the repair and sand it, you can go to a dealer and get color match hardtop paint to finish it up.
Old Feb 24, 2013 | 04:53 PM
jeramiej's Avatar
Default Fiberglass repair
I decided that since I don't leave til Tuesday I would do it myself . I got a good coat on it tonight and will let it set until the am and then hopefully sand it and paint it and be good to go
Old Feb 24, 2013 | 05:38 PM
Ryan0260's Avatar
Good call. Take your time, I'm sure it will turn out great.
