Pro Comp Wheel and Tire Combo
Old Feb 24, 2013 | 04:14 PM
csimp79's Avatar
Default Pro Comp Wheel and Tire Combo
I've been thinking about ordering the combo from Quadratech (Pro Comp Xtreme All Terrain Radial Tire on 7069 Series Alloy Wheel Qty 5). I like the rim style, it's all black and simple, but will be enough to look good with Billet Silver. I'm leaning toward the 32x11.50R17 on 17" x 9" 4.75" BS. I don't plan on putting a lift on my JK (2013) for a while and was wondering if anyone had any clue as to if it would cause any type of rubbing or any other issues. Thanks!
-csimp79 (newb)
Old Feb 24, 2013 | 09:25 PM
20JK10's Avatar
You may get slight rubbing under full lock [like doing parking lot maneuvers] on the front air dam. Easy solution is to just remove that piece of plastic.
I take it you are looking at the current tire/wheel combo package Quadratec is offering right now? I have the same exact 17x9 wheel on my Jeep and also like the way they look. While 17" wheels look good and are the same height size as factory, a 16" [which the 7069 is available in] will have a cheaper selection of tires in the same size as the 17" wheel. I would give Quadratec a call to see what they can offer you in both 16" and 17".
Old Feb 25, 2013 | 02:25 PM
csimp79's Avatar
Thanks man. Where at in OH are you from? I'm stationed down in Georgia right now and come home a decent amount. If it's anywhere near Cincy, I'm from Lawrenceburg, IN. (Argosy/Hollywood Casino).
Old Feb 26, 2013 | 02:30 PM
20JK10's Avatar
I'm way over on the other side of the state near the PA line.
