33.8" tires
Old Feb 28, 2013 | 05:19 AM
mainejeeper's Avatar
Default 33.8" tires
After tons of research on old posts, Im about to buy 33.8" MTR tires for my 2008 2 door Rubicon. It's got an AEV 2" spacer suspension lift. I plan on mounting my new tires on AEV Pintler wheels that offer more back spacing than the stock wheels.
Wich would fit better, 285/75 R17 or 305/70 R17? Both tires are nearly 34" tall. Anyone see a problem with either of these? It's an expensive purchace, I want to be sure fits!
Thanks,
Nathan
Old Feb 28, 2013 | 05:58 AM
Wrangeler X's Avatar
I'm right there with you! I bought duratracs 265 70 17 before my 2.5 teraflex spring lift and now they are too small an i am regretting it! Not so much the duratracs, but the size. I am thinking about selling these tires and getting the sizes you referenced. If I do I will really struggle between duratracs and MTR.
Duratrac is a great tire. So is the MTR. How did you decide on MTR? Please please post pics when done so I can make my choice also.
Also, triple check your overall height. I thought size is 33" flat... Did you do the math or measure them? It would be great if yor right and that may help my decision.
ID:	427794   Click image for larger version
Old Feb 28, 2013 | 06:27 AM
JK-jeepit's Avatar
I just went thought this also.. I wanted a tire close to a 34" from the discount tire calculator here is the difference in the two sizes I was looking at.. keeping with a 17" rim.
I ended up buying the Toyo MT's 285/75/17 and should be getting them Friday.
[TABLE="width: 316"]
[TR]
[TD="width: 110, bgcolor: transparent"][/TD]
[TD="width: 68, bgcolor: transparent"]stock
[/TD]
[TD="class: xl63, width: 68, bgcolor: transparent"][/TD]
[TD="class: xl64, width: 53, bgcolor: transparent"][/TD]
[TD="width: 72, bgcolor: transparent"][/TD]
[TD="width: 49, bgcolor: transparent"][/TD]
[/TR]
[TR]
[TD="bgcolor: transparent"][/TD]
[TD="bgcolor: transparent"]285/75/17
[/TD]
[TD="class: xl63, bgcolor: transparent"]285/75/17
[/TD]
[TD="class: xl64, bgcolor: transparent"]Gain
[/TD]
[TD="bgcolor: transparent"]305/70/17
[/TD]
[/TD]
[/TR]
[TR]
[TD="bgcolor: transparent"]Sidewall Height
[/TD]
[TD="bgcolor: transparent, align: right"]7.53
[/TD]
[TD="class: xl63, bgcolor: transparent, align: right"]8.42
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]0.89
[/TD]
[TD="bgcolor: transparent, align: right"]8.41
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]0.88
[/TD]
[/TR]
[TR]
[TD="bgcolor: transparent"]Section Width
[/TD]
[TD="bgcolor: transparent, align: right"]10.04
[/TD]
[TD="class: xl63, bgcolor: transparent, align: right"]11.22
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]1.18
[/TD]
[TD="bgcolor: transparent, align: right"]12.01
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]1.97
[/TD]
[/TR]
[TR]
[TD="bgcolor: transparent"]Overall Diameter
[/TD]
[TD="bgcolor: transparent, align: right"]32.06
[/TD]
[TD="class: xl63, bgcolor: transparent, align: right"]33.83
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]1.77
[/TD]
[TD="bgcolor: transparent, align: right"]33.81
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]1.75
[/TD]
[/TR]
[TR]
[TD="bgcolor: transparent"]Circumference
[/TD]
[TD="bgcolor: transparent, align: right"]100.72
[/TD]
[TD="class: xl63, bgcolor: transparent, align: right"]106.28
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]5.56
[/TD]
[TD="bgcolor: transparent, align: right"]106.22
[/TD]
[/TD]
[/TR]
[TR]
[TD="bgcolor: transparent"]revs per mile
[/TD]
[TD="bgcolor: transparent, align: right"]629.03
[/TD]
[TD="class: xl63, bgcolor: transparent, align: right"]596.15
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]-32.94
[/TD]
[TD="bgcolor: transparent, align: right"]596.5
[/TD]
[TD="class: xl64, bgcolor: transparent, align: right"]-32.59
[/TD]
[/TR]
[TR]
[TD="bgcolor: transparent"]MPH
[/TD]
[TD="bgcolor: transparent, align: right"]65
[/TD]
[TD="class: xl65, bgcolor: transparent, align: right"]68.59
[/TD]
[TD="class: xl67, bgcolor: transparent"][/TD]
[TD="class: xl66, bgcolor: transparent"][/TD]
[TD="class: xl67, bgcolor: transparent, align: right"]68.55
[/TD]
[/TR]
[/TABLE]
Old Feb 28, 2013 | 06:32 AM
My buddy has 285 70 17 duratracks and he measured them At just under 33"
Old Feb 28, 2013 | 06:33 AM
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
What is all of that?
Old Feb 28, 2013 | 07:57 AM
JK-jeepit's Avatar
If you view it from a computer and not a mobile device it's a table that shows the difference in sizes of stock 255/75/17 vs 285/75/17 &305/70/17
Thought it might be useful for the op
Old Feb 28, 2013 | 12:59 PM
Thanks for the input everyone. My measurements came from online tire conversion programs that convert metric to standard sizes. I have no first hand knowledge of actual heights. I struggled between the duratrac and mtr, but settled on mtr because I'm looking to get the best traction offroad. It is my daily drier, but when I offroad, I count on my nearly stock (in the suspension department) rubicon to get the job done. I've got a set of wheels and tires off a Sahara that I bought cheep. I use them for long road trips.
Keep your thoughts commit everyone! Unfortunately, it looks like the mtr only comes on the 305 size, which may be to wide. I have no way of knowing.
Old Feb 28, 2013 | 03:21 PM
zero_traction69's Avatar
I am running a 285/75r17 toyo open country 34.1 with only a front level kit, should fit prefect
Old Mar 1, 2013 | 10:24 AM
I'm guessing the actual measurements from tire to tire and manufacturer to manufacturer vary. You best to measure the tires you want in person. Looks like a pretty different actual
Measurement from
TOYO to GY.
Old Mar 1, 2013 | 10:58 AM
bsmarble's Avatar
My Toyo AT2s that are 285/75/17 measure 33.1" don't trust manufactures numbers they are rarely accurate. Ask forum members to get real world measurements. I have 1.5" wheel spacers and a leveling kit. No problems. Wish I went with 35s though. Good Luck.
