Wheel Backspace Recommendation
Old Feb 28, 2013 | 09:53 AM
MikeMefford's Avatar
Default Wheel Backspace Recommendation
What wheel backspacing do you recommend and where does that leave the tire setting in comparison to the fender? Thanks
2013 JKU
RK 2.5 Max Travel
35X12.50X18
18X9 Wheel
Old Feb 28, 2013 | 10:21 AM
filthy-Beast's Avatar
2013 JKU
RK 2.5 Max Travel
35X12.50X18
18X9 Wheel
Stock Rims are typically 7.5" wide with a 6.25" backspace. Stock tires are 10"
When going up to bigger wider tires you want 4.5 to 4.75" back spacing.
So If I did the math correctly your 12.5" wide tires with 9" rims that have a back space of 4.5" will move 3.75" further out than stock.
Old Mar 1, 2013 | 08:25 AM
eumel789's Avatar
Thumbs up
2013 JKU
RK 2.5 Max Travel
35X12.50X18
18X9 Wheel
Maybe a look at my web page helps a little :-)
http://www.sor7.com/JEEP-Tires.html
Old Mar 1, 2013 | 10:41 AM
Wandell's Avatar
Loved
The most common setup is a 9 inch wide wheel with 4.5 inches of backspacing. Here's what it looks like with a 12.50 inch wide ttire.
Old Mar 1, 2013 | 01:07 PM
Runewolf1973's Avatar
I have 18x9 Level 8 Trackers and they have 5" of backspace. They work perfectly with no rubbing anywere...lots of clearance. They actually stick out of the stock fenders a lot more than I was anticipating... I think 5" gives a nice stance...
