On Board air vs. Powerplant Winch opinions
Old Feb 28, 2013 | 03:25 PM
azsandrider's Avatar
Default On Board air vs. Powerplant Winch opinions
I need 'educated' opinions on the best way to have air.
I have a 2012 JK 2dr Rubicon with a Teraflex 3" longarm lift & 35" tires. I run between 28 - 32 #s on the street and air down to 12 #s.
Since I have a 2dr, storage space is important to me and I don't want portable air compressors or air tanks in the way. (I go on several back country Jeep camping trips a year - some too rugged to tow a trailer)
I'm considering an Expedition one Core series bumper and a Warn Powerplant winch with synthetic rope. The bumper will allow the large winch to sit low. The cost of the winch and then the extra cost of the rope is a lot of $$$. (I want the rope to save weight up front.) The plus is that the winch is an air compressor too. Does this unit do a reasonably good job at airing up tires?
I am also considering a PSC Brawler Lite bumper with a standard winch with rope to save weight and put a separate on board compressor. The problem is the the 2012 has little options to mount a compressor and air tank. (I always want the next larger system than needed). The cost of a quality winch with synthetic rope and the on board compressor should be several hundred $$$ less but there will be more labor to install both items. Which on board compressor system works well and that fits on a 2012? Is having an extra air tank helpful? I'll need to protect any tank as I sometimes boulder hop and may slip off and hit the frame.
What works for you?
Thx...
Old Feb 28, 2013 | 03:34 PM
JK-Ford's Avatar
I can't comment on makes / models. But I've never been a fan of those "all-in-one" deals. Usually you have to sacrifice the performance of both to get them both in the same package. And if you have problems with one, the other piece makes the repairs more complicated. It may be more trouble up front to do separate systems. But you will end up with a better system all around.
Old Mar 1, 2013 | 06:12 AM
darkhelmet's Avatar
I have the Viair 400H mounted underhood on my 2012 and like it. I am only currently running 265/75-r16, but it has NO problem airing them up quickly. The underhood mount is pretty slick too.
Old Mar 1, 2013 | 12:54 PM
RDH475's Avatar
Default air compressor
What works for you?
Thx...
I have the Warn powerplant 12,000lb powerplant & I am 100% satisfied it puts out out 5cfm per min @ 90psi with a long duty cycle { I dont rember the exact stats } I have aired up 2 jeeps one after the other and did not slow down. I dont think Warn sacrificed on either end. The biggest thing I have pulled out was a full size bronco in mud up to his floorboards NO problem. I dont regret spending the extra. Engo makes one with a air compressor but it only puts out 1/3rd the cfm's of the Warn. I am in the same boat as you 2dr. no room for extras.
