Genright Coilover Mounts With King Coilovers 14"
Old Mar 1, 2013 | 11:31 AM
Maertz's Avatar
Default Genright Coilover Mounts With King Coilovers 14"
Is anyone currently running this set up?
Gen-Right Preimum Front Shock Hoop Kit
GenRight Rear Shock Mount Kit
If so i am wondering if you needed anything else like limiting straps or if you ran into any issues? Whats the lowest lift you might have?
i know i would still need to get extended brake lines as well as the sway bar links.
I appreciate all help.
Thanks,
Maertz
Last edited by sm_rubi; Mar 10, 2013 at 02:02 PM. Reason: non-sponsor links broken
Old Mar 1, 2013 | 06:29 PM
LoPo's Avatar
Honestly give them a call and talk through what you're thinking. They have a JK specific application that goes through the tub. When you outboard coilovers you need a wider axle. They show a minimum of 5" between frame and wheel bulge with this particular mount.
LoPo's Avatar
And post up what they say, because I'm interested.
Old Mar 1, 2013 | 09:38 PM
Maertz's Avatar
I will have to wait until Monday but i am thinking i might have the clearance im running 2.75 backspacing.
Im mainly curious to see how tall the mounting towers are compared to evos. If they can be mounted like an inch or 2 higher and i can fit a 14 coilover at about 4 to 5 inch lift that'd be great. I need to know if id need limiting straps or what else to worry about if i could fit themm
Old Mar 1, 2013 | 09:51 PM
Mackey's Avatar
I have seen GenRights JK with the coil overs and towers and it did have limiting straps. Hope that helps. Call the shop and ask for Dave. He will answer any questions you have. Keep us posted if you do it.
Old Mar 1, 2013 | 10:37 PM
Maertz's Avatar
See id like to run 14" around 4 to 5 but dont wanna mess with limiting straps. Theres gotta be a way to run 14s without a strap n not spend an assload. But ill have to wait and see.
Old Mar 2, 2013 | 03:40 AM
helnbk's Avatar
You spend a couple of thousand on coilovers, and don't want to <$100 for limiting straps to protect your investment?
Old Mar 2, 2013 | 04:42 AM
Maertz's Avatar
No i want to use the full travel or get 12".....
Old Mar 2, 2013 | 05:53 AM
Nwapache's Avatar
Uhhh, you know limiting straps have a reason for existing, right?!
Old Mar 2, 2013 | 06:19 AM
Maertz's Avatar
Of course.
