Uhhh U-Joint Problem??
Old Mar 2, 2013 | 10:14 AM
Waldo_88's Avatar
Default Uhhh U-Joint Problem??
Today while getting ready to change my ball joints I noticed this....How the hell does this happen?? Has anyone else dealt with this?
Name:	u joint.jpg
Old Mar 2, 2013 | 10:19 AM
Abritinboston's Avatar
Mine did the same thing! Had to be replaced, I noticed it when putting on new shoes
Old Mar 2, 2013 | 10:25 AM
Waldo_88's Avatar
What parts did you replace, and did you do it yourself?
Old Mar 2, 2013 | 12:10 PM
Smashboogie 4x4's Avatar
Former Vendor
The U-Joint Cap fell off.
All you need is to get new U-joints and then replace pull the pieces apart and put it back together. It is something that could be done if you are mechanically inclined.
Old Mar 2, 2013 | 12:34 PM
Waldo_88's Avatar
but the piece that's missing really isn't part of the u-joint...
Old Mar 2, 2013 | 12:39 PM
ronjenx's Avatar
The piece that's missing is the bearing, which comes with the new u-joint.
The repair is as simple as stated above only if the bore has not been damaged.
Old Mar 2, 2013 | 12:41 PM
Waldo_88's Avatar
gotcha, thanks
Old Mar 2, 2013 | 01:47 PM
I had a stealer ship do it as I assumed it would be more than my meager mechanic skills could handle. It was bloody expensive and realizing how much I could have saved made me want to cry. Definitely give it a shot yourself
Old Mar 2, 2013 | 02:10 PM
ronin2120's Avatar
Vet Army
It's not as difficult as you might think, but make sure you have the right tools. I ended up installing a new on my rear drive shaft in a hotel parking lot using a large C clamp. Huge PITA but it worked.
