Installing RK 2.5 flex. Do I needto extend my breather hoses?
Old Mar 3, 2013 | 09:06 AM
Learo2000GT's Avatar
Default Installing RK 2.5 flex. Do I needto extend my breather hoses?
Do I need to extend my breather hoses with the rk 2.5 flex lift? Is So can I cut the exsisting breather hose and put extra length in with a hose barb or is there a better method? Thanks in advance.
Old Mar 3, 2013 | 09:12 AM
OH9JK's Avatar
JK-Forum Ambassador
Not necessary for a suspension lift but a good idea anyhow.
River Raider has a kit that has all the parts and pieces although it is pretty easy to do yourself.
Smilin' Bob's Breather Hose Extension Kit for JKs
Old Mar 3, 2013 | 09:14 AM
scubatech's Avatar
I extended mine 3" just to be sure. i didn't want to take a chance on it pulling out. I did it just like you mentioned.
Old Mar 3, 2013 | 09:26 AM
Thanks guys. I will splice in some hose and hose clamp it in. You say 3 inches is the amount you added? Did you do front rear and diff?
Old Mar 3, 2013 | 11:26 AM
EzK's Avatar
EzK
You could add 2ft to the rear and easily run it up through an existing opening to the height of the rear tail light.
Up front you can add a few feet also and get it back and up on the firewall.
Old Mar 3, 2013 | 12:14 PM
Smashboogie 4x4's Avatar
Former Vendor
For now we extended our breathers because they kept pulling off of the axle.
The ultimate thing to completely redo your breather set up and route it into the air box. This would be the best way to go especially if you have a snorkel.
Old Mar 3, 2013 | 12:19 PM
Drix's Avatar
I added a R/E 3.5 mid arm kit in nov. went off roading durning a thaw in dec and notice my breather tube just hangin, so I took the front cover off to see how bad the damage was, since I knew it was in DEEP water! Omfg! So glad I drained the front diff. It came out like a triple thick milkshake! I have since extended my breathers!
Old Mar 3, 2013 | 05:19 PM
c4bus's Avatar
If you play in water or mud, extend your breathers. Do it regardless of your lift. It is a $10 project that can save you thousands.
Old Mar 3, 2013 | 05:33 PM
Thanks for all the help guys. I have been a hot rodder my whole life and have recently got into jeepin. Mod bug has bitten bad and it's an education process which u guys are helping with tremendously
