Where/how did you run your stainless steel brake lines?
Old Mar 3, 2013 | 04:15 PM
Mschneid's Avatar
Default Where/how did you run your stainless steel brake lines?
I have a 2012 Unlimited and I'm looking to add longer SS beake lines. It is my understanding that the 2011-2013 run under and behind the front shock so I was wondering what you did, did you route them the same way or different? Pictures if you have them, please.
Old Mar 3, 2013 | 04:27 PM
GreenJK07's Avatar
I followed the trac bar for the rear and zip tied them down. Works great and keeps it clean. For the front I zip tied them down to the bottom mount of the shock (axle side).. I don't have pics currently....
Old Mar 3, 2013 | 04:43 PM
c4bus's Avatar
Take the time and read through this. Rock Krawler chimes in with some very valid points and pictures. And disregard the thread title. There are no problems if you follow the instructions.
https://www.jk-forum.com/forums/modi...13-jks-254578/
Old Mar 4, 2013 | 02:36 PM
Gman*2007's Avatar
I've got the crown extended brake lines and ran them in the same path as the factory lines with no problems. No pictures.
