Tire & Wheel Combo - Fit? - ProComp
I'm thinking of purchasing the ProComp Extreme All Terrian 33x12.50r17 mounted on ProComp 7069 Wheels. The backspacing on the wheels is 4.75". Do you think I can fit these on a STOCK 2011 Wrangler Sport without lift? Will they rub and if so will it be a big problem? I currently have the stock SRA's on 17" wheels and want to change them up. I like the stock wheels but do not like the idea of spacers. Any problems mounting this combo on stock spare tire setup? I plan to lift but wasn't sure if I could start with tires and then do lift or should i lift first and then do tires and wheels. I'm working with a budget.
Thanks,
Don
Thanks,
Don
I would say they might be alright, maybe some rubbing at full turn but iv seen 35" on a stock jeep not sure what the back spacing on the wheel tho was. Stock tire carrier your just gunna have to extended the bump stops but a 33" tire shouldn't be to big of a deal on the stock tire carrier.
