Rear Trackbar Bracket?
Old Mar 5, 2013 | 09:06 PM
mudking's Avatar
Default Rear Trackbar Bracket?
I just got mt TF 2.5 lift for my 4 door jk. I noticed I didnt have this bracket, in the install video it says if included. Do I need this or no?
Old Mar 5, 2013 | 09:07 PM
k0260's Avatar
They're great insurance to have to strengthen the oe axle trackbar mount and raise your roll center. I use TF's HD trackbar mount.
Old Mar 5, 2013 | 09:09 PM
aldaman's Avatar
Yes, because it helps recenter your axle once its lifted...But you can temporarily run w/out one until you get the bracket or opt to get a rear adjustable track bar...
Old Mar 5, 2013 | 09:13 PM
mudking's Avatar
I have the rearend bracket so I would also need to frame mounted bracket along with that?
Old Mar 5, 2013 | 09:43 PM
c4bus's Avatar
Is anyone running the RK rear adj trac bar and bracket?
Old Mar 6, 2013 | 12:40 AM
aldaman's Avatar
No, it's one or the other.......
Old Mar 6, 2013 | 12:42 AM
aldaman's Avatar
I'm using the RK axle mount TB bracket and the TF adjustable rear track bar...
