Help! Multiple clicks, no start
Old Mar 10, 2013 | 08:04 AM
Phil6mac's Avatar
Default Help! Multiple clicks, no start
I was installing a daystar switch panel and shifted the shifter to 1 (moved towards me for more space to install lower dash panel). Also moved the 4wd shifter back too. 08 jk started fine before this...now, when I try to start, it seems to have enough power, but I just get a click...click...click... Checked battery and iod fuse, disconnected the battery and hooked back up, still no start. The keyless entry still works. Thoughts?
Old Mar 10, 2013 | 08:14 AM
jaker t5's Avatar
Put it in neutral and see if it will start
Old Mar 10, 2013 | 08:16 AM
Ryan0260's Avatar
Are all the dash lights coming on? Are you sure you have a good battery connection?
Old Mar 10, 2013 | 08:23 AM
jacksup's Avatar
still sound like battery , test it
Old Mar 10, 2013 | 08:30 AM
Phil6mac's Avatar
Tried this. No start. Just clicks.
Old Mar 10, 2013 | 08:32 AM
Phil6mac's Avatar
Lights come on on the dash radio powers up and everything. Took the terminals off the battery and cleaned, replaced. No start.
Old Mar 10, 2013 | 08:37 AM
JK-1's Avatar
yep i would say bad battery....take it out and take it to a local autozone or something like that they will load test it for you
good luck
Old Mar 10, 2013 | 08:45 AM
Phil6mac's Avatar
Will test this next and report back. Thanks
Old Mar 10, 2013 | 09:57 AM
Team Desert Eagle's Avatar
I have an 08 and had the same issues. When I get the click I just run the gear selector all the way down and then back up into park and it starts up on the next try.
Old Mar 10, 2013 | 12:18 PM
Phil6mac's Avatar
It was the battery. Had to let it sit and charge for a while being jumped. Gonna have to get a new one...about 5 years old. Appreciate all the help!
