1.5 " lift kit.
Old Mar 15, 2013 | 07:32 AM
MA_Jeep's Avatar
Default 1.5 " lift kit.
Hi I have ordered teraflex 1.5 lift/level kit. (Part # 1351500) and I was wondering with adding a lift if I have to get different break line brackets or anything? The kit is 4 new springs and away bar links
Old Mar 15, 2013 | 07:37 AM
shockwaveaz's Avatar
Not needed with that kit.
Sent from my Galaxy Note 2
Old Mar 15, 2013 | 08:21 AM
MA_Jeep's Avatar
Okay even at full flex it will be good?
Old Mar 15, 2013 | 08:24 AM
Ncb's Avatar
Ncb
If you retain the stock shocks you don't need to extend the brake lines because the down travel of the suspension will remain the same.
Old Mar 15, 2013 | 10:07 AM
MA_Jeep's Avatar
Okay thanks sorry I am a newb when it comes to suspension
Old Mar 15, 2013 | 11:43 AM
Ncb's Avatar
Ncb
No need to be sorry for asking.
Old Mar 15, 2013 | 12:15 PM
MA_Jeep's Avatar
If I purchased shocks with a longer stroke( travel) would I have to extend the brake lines or what size lift would they have to be done at?
Old Mar 15, 2013 | 12:52 PM
In most cases you will not need to extend your brake lines unless you buy shocks that are meant for a bigger lift or a long travel setup. I had to buy them with my 2.5 TF lift because I was running OME long travel shocks. Your shocks will be your limiting factor with the lift you are getting. Even with shock extensions, you will be fine. Your stock shocks will be just fine with that setup. You're GTG with the stock shocks and no brake line extensions.
If you are going with longer shocks you will need to start getting into alot of other things. Bumpstops coil retainers extended breather tubes and driveshafts to do it right (don't know your yr model transmission)
Old Mar 15, 2013 | 02:24 PM
MA_Jeep's Avatar
Originally Posted by shockwaveaz
In most cases you will not need to extend your brake lines unless you buy shocks that are meant for a bigger lift or a long travel setup. I had to buy them with my 2.5 TF lift because I was running OME long travel shocks. Your shocks will be your limiting factor with the lift you are getting. Even with shock extensions, you will be fine. Your stock socks will be just fine with that setup. You're GTG with the stock shocks and no brake line extensions.
Okay thanks it's a '12 6 spd. I think I'm just gonna stuck with stock shocks then for now
