Parts needed to regear?
Old Mar 17, 2013 | 09:02 AM
enash965's Avatar
Default Parts needed to regear?
So I have a 2012 JK 6 Spd and want to regear from my stock 3.21s to 4.56 since I'm running 35s. Can anyone fill me in on what parts I need to order/reliable brands? Thanks
Old Mar 17, 2013 | 09:06 AM
slider_68's Avatar
New front carrier, gears, install kits and 4 qts of 75w90.
Northridge4x4 has a package deal on gear sets and master install kits for $659 in the 4.56, they can also hook you up with the carrier
Old Mar 17, 2013 | 09:48 AM
JK xx-LSD-xx's Avatar
Why would he need a new carrier?
Ring and pinion set w\Master install kit..... Since you have a New Jeep assuming low mileage you can get get away with a Minor install kit and use your existing bearings if they don't get damaged during tear-down.
If you've never done a re-gear add $300-$400 per axle or around $1400 for professional install. In a shop knowing what you are doing will take 6-8 hrs with proper tools. I Just paid to have mine done and what a difference
it makes. The savings in improved mileage will pay you back at the pump. I got 3-5 mpg increase and less stress on your Vehicle. Shop around there are some good deals out there. I got free Diff covers @ $130 a peice from G2.
Price for Master vs. Minor install kits Basically $75-100 per kit as the Master includes the bearings.
And for JK 07-12 SAE 85W-140 HD Gear oil.
Old Mar 17, 2013 | 09:52 AM
enash965's Avatar
What kit and gears did u go with
Old Mar 17, 2013 | 10:09 AM
jaker t5's Avatar
He needs a new carrier because he has 3.21 gears , anything under 3.73 needs a new carrier
to go above 3.73
Old Mar 17, 2013 | 10:11 AM
enash965's Avatar
to go above 3.73
A new Dana axle?
Old Mar 17, 2013 | 10:19 AM
jaker t5's Avatar
Originally Posted by enash965
A new Dana axle?
No new axle just the carrier for the gears
Old Mar 17, 2013 | 10:43 AM
afpilot82's Avatar
JK-Forum Ambassador
Are you going to do the regear yourself? Have you done it before?
Old Mar 17, 2013 | 10:50 AM
to go above 3.73
You are correct I already had 3.73 so that never crossed my mind.
I went with G2 ring and pinion set mainly because of the free diff covers as I was going to buy some anyway and they are around $100-$150 apiece so I couldn't pass it up.
I believe you have standard gears in the rear jk d44 and reversed up front in the jk d30.
Old Mar 17, 2013 | 11:04 AM
enash965's Avatar
I've never done it before and with my jeep being so new I plan to have it done by someone else
