teraflex 2.5" lift kit with rockkrawler coils
Old Mar 21, 2013 | 12:45 AM
Lim@'s Avatar
Default teraflex 2.5" lift kit with rockkrawler coils
Hey guys. I can't get the full 2.5" rk stock mod kit because the trackbar is only for LHD cars and mines a rhd. So Bryan from 4wd.com has proposed the teraflex 2.5" coil lift kit but with the rock krawler progressive springs and then I would add the bilstein 5100 shocks.
Can anyone see any issues with this? Am I going to have an issue not having the track bar that these coils are meant to come with?
BTW for a 2007 Rubicon 2dr
Thanks
Old Mar 21, 2013 | 01:25 AM
OH9JK's Avatar
JK-Forum Ambassador
Full Traction Suspension makes front and rear adjustable trackbars for RHD Jeeps.
Old Mar 21, 2013 | 01:28 AM
OH9JK's Avatar
JK-Forum Ambassador
Teraflex makes adjustable trackbars for RHD Jeeps too
| TeraFlex Suspensions
Old Mar 21, 2013 | 02:21 AM
Lim@'s Avatar
Thanks for that. But will I be able top use the Terra flex kit with the rk coils as is our do I have top get an adjustable track bar etc to run them? The teraflex comes with a track bar bracket
Old Mar 21, 2013 | 07:14 AM
Rock Krawler Suspension's Avatar
Former Vendor
It should be a good combination! Sorry we do not do RHD products as 99% of our business is in the states...
Good luck with your build!
RK
Old Mar 21, 2013 | 11:39 AM
Lim@'s Avatar
Thanks mate so you can't see any issues with just the springs and the stock teraflex fitting kit without buying other gear?
Cheers
Old Mar 21, 2013 | 12:37 PM
SpicedCrusher's Avatar
You won't have any issues. By the way Bryan really knows his jeep parts.
Old Mar 21, 2013 | 01:10 PM
Lim@'s Avatar
Sweet thanks guys
Old Mar 21, 2013 | 01:21 PM
mpkelley20's Avatar
Just curious what parts will be TF and what will be RK. RK front coils are the only ones that are progressive. The rears are linear.
So are you getting RK front coils, TF rear coils? Or RK for both?
And will the sway links be TF? The 2.5 coil kit comes with new rear links and you move the stock rears to the front.
And I assume the only other part is the track bar bracket??
If I were you I'd spend the little extra money and get an adjustable track bar. If you do that, maybe you can get a full matching kit.
Old Mar 21, 2013 | 05:19 PM
Lim@'s Avatar
Hey mate. Getting rk coils front and rear. The rest of the gear is tf. So everything that comes in the tf kit eg track bracket sway bar links etc. If they only have the one pair of sway bar links then I would assume I swap stock rears to the front
