rear diff fluid change
Old Mar 23, 2013 | 05:26 PM
marine11's Avatar
Default rear diff fluid change
Changed rear diff fluid today and took a little under 2 quarts. I was expecting closer to 2.5. Stock diff cover on 07 rubi. Could it be because my lift has my axle at a little different angle? Thanks
Old Mar 23, 2013 | 05:30 PM
tcdawg's Avatar
Should take 2 3/8 quarts.
Seems like you would really have to have that pinion pointed way up to only get 2 quarts in.
Old Mar 23, 2013 | 05:37 PM
marine11's Avatar
I noticed my rear coils have a slight bend to them towards the rear. I put my lift on last year and had dealership dial it in. Will it hurt having under 2 quarts in rear diff?
Old Mar 23, 2013 | 06:09 PM
tcdawg's Avatar
Many lifted jeeps have there rear pinion adjusted up slightly to match the DS angle. I do. But I haven't heard of anyone being able to put in only 2 quarts of gear oil.
Jeep calls for 2 3/8's or 4.75 pints. You are quite a bit less than that. I would look into just how much your pinion is shifted up. Pic?
Old Mar 23, 2013 | 06:16 PM
marine11's Avatar
Sorry no pics. I would have to have the wife help. Im computer retarded. Im not impressed with the dealership here. I think I will try to figure the pinion out myself. Im sure I can find a post on how to set it.
Old Mar 24, 2013 | 07:17 PM
Tripletsi's Avatar
I changed the rear gear oil in my 2012 JKU Sahara and was only able to put in 2 quarts before it started spilling back out. No big deal, just screw the plug back in (stock cover).
Old Mar 24, 2013 | 08:39 PM
Rocky Clymer's Avatar
I just drained and filled my rear diff three days ago, only took about 2 qts before being totally full.
ronjenx's Avatar
The important thing is to have the oil high enough to get out to the axle bearings.
That means higher than the bottom of the axle tube.
Since you can't fill higher than the fill hole, you need to find out if the bottom of the fill hole is higher than the bottom of the inside of the axle tube.
If the hole is too low, you can get an aftermarket cover with the fill hole much higher. Then make a little dip stick to use when you refill the diff. Make sure the oil level is higher than the bottom of the axle tube.
Old Mar 24, 2013 | 08:43 PM
k0260's Avatar
With my pinion tilted up, on level ground I could only put 1 3/4 qts in the diff. I back up on some 8" tall ramps to get a nice angle to fill the right level.
