I need some opinions here
no, it would look fine but it is more then you need. The question is are you going to be able to do everything needed to run a properly set up 3.5" lift? If you are looking at one of those $500 kits you will be spending quite a bit more before you are all said and done.
That's about perfect especially with the stock flares. Less than that and you really need to watch your bump stops if you disconnect off road and run the rocks. With flat flares you gain a couple inches of uptravel.
