1/2" Rear Guide & Spacer
Old Mar 25, 2013 | 03:15 AM
magnum.pi's Avatar
Default 1/2" Rear Guide & Spacer
Hi Guys, I'm installing 4 new Bilstein shocks 2-3.5" on my TF 2.5 lift kit;
may I need to istall also the rear reteiners to avoid to loose the springs in the max. extension?
Tks
Mpi
Old Mar 25, 2013 | 04:48 AM
aldaman's Avatar
If your lift kit came with it, I would install them + it will give that added height. If it didn't come with it a low cost option would be to use those big hose clamps and clamp the lower spring to the axle....
Old Mar 25, 2013 | 05:25 AM
magnum.pi's Avatar
No my kit borns without it but the length of shocks covers from 2" to 3.5" so, I suppose, there is the chance to loose the spring also if the TF 2.5 lift kit is near to 3".....
